Is it just me or did they get the concept of Hammerschmidt backwards?
I think they should have had "underdrive" instead of overdrive. Would be better to be on 1:1 in the larger ring since that is the one a rider spends most of the time in. Would use the "gearing" then only in the less often used granny gear. Better efficiency then for most of the pedaling. Plus then the system would work better with the different suspension designs since you would be on a 34 chain ring instead of a 22.
What am I missing on this subject?
