Building up a Transition Vanquish with parts from the good ole parts bin, and I can't get the indexing worked out. GX eagle drivetrain with non-boost crankset. Chainring as inboard as possible without rubbing. Non-boost wheelset using conversion kit. Conversion kit moves chainline in 3mm, but I probably have the chainring 2mm further in that normal boost chainline. Difference should only be about 1mm.
Brand new housing
Brand new cable
Drivetrain working great on last bike
Has been sitting in parts bin probably 3-4 months
Symptoms are that won't shift down or up consistently. Once I tighten cable enough to shift out of smallest cog, it will not shift down anymore. Loosen it, and it won't shift up (lower gear). B limit set with eagle spacing tool. Upper and lower limits about 1/4 turn out from touching. Checked hander jic, and its straight. Similar symptoms to friction from worn/dirty cable/housing, but they are brand new.
Any ideas?
Brand new housing
Brand new cable
Any ideas?
