If memory serves me well the ETT on the GT frames are pretty generous. I think the Small GT Peace has something like a 23 or 23.5" ETT or thereabouts. If that works for you at 5'10" tall you should be golden.
WHY???markaitch said:don't do it!!!
Hello JD,jdinsj said:Was looking at this bike and wondering the same thing. I'm 5'8" with a 32" inseam. Shorter upper body with longer legs. What is anyone riding with similar dimensions?
Thanks,
JD
sounds good....no overlap...i wear a 43 shimano.jdinsj said:Yes, I got the green.
Got the fit set and installed clipless pedals. No toe overlap. It's close, probably less than an inch. I wear a 44 shoe with the clips positioned all the way back.
Might need a longer post. Not at the minimum line, but I think the bottom of the post isn't below the bottom of the top tube. If I had gotten the medium frame size, probably would have needed a shorter stem.
Plan to ride a trail Saturday morning.
