Ok folks, I gots me a 2001 Santa cruz Super 8. Last year I did some maintanence and changed the shock bushings with new stuff from Fox. When I put the shock back on the lower mount had some vertical play in it. So I let it go for another year and this year I ordered new bushings again and got a new bolt from the hardware store. Put it all on and still have vertical play.
It appears like the bolt is too small, or the bolt hole in the bushings is too large. The bushings fit nice and tight into the shock eyelet. If you grab the seat and lift the rear of the bike and look real close you can see the shock lift up and down a tiny bit on the shock bolt, maybe about 1mm. When you pick up the bike there is a small clunk.
So what's the deal here? I have all new hardware and there's still play. If you are familiar with Super 8's, there isn't a bolt and nut used to mount the lower end of the shock. It just uses a bolt that threads into a "shock shuttle" which is a machined piece, so there's no way I have the wrong size bolt, or the threads wouldn't match up and it would never go in. Then this shock shuttle is bolted onto the swingarm. The play is defenitely in the lower shock mount, nowhere else.
Any suggestions? And don't tell me "Super 8's suck, go buy something else!"
