1 - 20 of 120 Posts
Time flies...
Got my Luv Handles installed. Will give them a test ride tomorrow...
Thanks Rody! :thumbsup:
one chain loop
nice. what happened to your headset? is it sitting well on the crown race like that?
one chain loop
jesseheath said:
the top and bottoms on kings are identical. ive seen a few people do that.
on purpose or by accident? anyways those groovys looks really nice, sorry i have to say it twice. :thumbsup:
haha actually a little bit of both. ive seen several people do it on purpose and one or two on accident.
and agreed... although im not a huge fan of unconventional bars.. those do look very nice.
Time flies...
Discussion Starter · #6 ·
This is the headset's second bike, so I rotated them... just because...
:D
it's....
Keep us updated on how those Ergon grips work with Luvs!
My wrists were killing me on first few rides with my Luv Handles until I found the correct grip angle.
Old, stale, negative
I see you dorked out and got the custom bar ends to match your headset just like I did. Rad. I think it looks great with the Ergons.
mudpie said:
I Run the Luvs on my SS as well and really like the foam grips with the rigid set up
Are those foam grips as fragile as they look?
I dread the thought of cleaning off bits of glued on foam every couple weeks just to replace grips.
I like butter
I always thought that about foam grips till I tried a pair of Bontrager Race X Lites and I love them. All of my Ourys will be replaced by them when they wear out. I have taken them on and off a couple of times easily with an air gun after gluing them. I always thought they would rotate but have had no problems with some pretty hard climbing last weekend which is when I usually rotate my Ourys even with glue.
Time flies...
Discussion Starter · #14 ·
First Ride Report
Put in a few mountain miles yesterday. After some trailside adjustments, I just couldn't quite get that 'magically delicious' feeling I was hoping for. Not bad, just not great.
I deduced that the bar felt too low and too close. Plus it's narrower than what I'm used to.
(I didn't find out that Rody makes these in 28" also until mine had already shipped. To his credit, he's offered to work an exchange if I need it...:thumbsup: )
I did notice some interesting effects though. I no longer felt like I was 'steering' the bike. It felt more like I was simply 'guiding' the bike. A much more intuitive feeling. Nice!
So this morning I swapped to a longer stem w/ more rise. And I replaced the Ergons with some normal grips. There are a lot of interesting angles going on with these bars and I want to get those all set before I put the Ergons back on...if I even do.
Driveway test says it feels much better already. I think the narrower width may not be an issue either...on this bike.
Hopefully I'll get to trail test it again tomorrow...
Lovin the Luv's in AZ
I installed my LH's on the Sendero SS and felt very comfortable almost from the get go,,,,,,,,,,,,,,,,not much of an adjustment as I would have thought coming from traditional riser bars.......... The LH's do seem to "guide" the front end more than "steer" it, as mentioned above in another post,,,,,,,,,,,,,,,very cool feeling on swoopy traversing trails.............thanks Rody:thumbsup:
xjbebop - from the looks of your first picture the grip ends may be angled too far up. Just a guess from a picture but you may like them better angled down.
it's....
I did that initially, coming from Mary, but that about killed my wrist.
Now that I rotated it up parallel, feels much better.
Reckon it depends on your stem, TT, etc.
They call me Shoogs
Funny. I'm trying to stuff my new white Luv into the Ergon and man it's tight. Super anxious to try the LUV
Time flies...
Discussion Starter · #19 ·
The first (mountain) picture was before I started tweaking. And that's one of the reasons I took the Ergons off.
I spent time today testing that angle and ended up with them pointing just above halfway between the saddle and the rear hub. Once I get out on the trail I'll be able to fine tune, if needed...
Hey BD,
The variability of how the bar feels dependant on rotation is one of it's greatest assests, allowing individuals to find the sweet spot in their own range rather than the piece dictating where it should be.
This diversity is also the bars hurdle, in that I have a LOT of folks who would like a one piece bar/stem combo, and it is next to impossible to divine each person's perfect fit without them owning the bar for a bit and then sending back imput on stem length, rise, and rotation.
Ironically, you touched on an issue I've seen frequently...the use of the foamies on the Luvs. Old school or not, folks tend to dig them. When you are riding hard there is just something so comforting about a plush foamy to nustle up in your palm.
Thanks for cluing me in on the thread :thumbsup:
cheers,
rody
1 - 20 of 120 Posts
