1 - 9 of 9 Posts
I'm trying to decide between the Aluminum or Carbon verison of the Ritchey WCS flat handlebars and one of my considerations is grips.
If I go aluminum, the decision is easy. ODI Rogue Lock-on's.
If Carbon, then I'm not sure if I want lock-on grips that might gouge the finish on the bars. Also, I'm not sure if the ODI bar plugs will fit since I think there's a type of aluminum insert in the carbon bars that decreases the inner diameter.
Questions is, what kind of grips are you guys running on your carbon bars? And is anyone running specifically the bars above?
I had a set of racer's edge esi grips come in at 41g for the set, and they're about 14564784x more comfortable than ritchey/bonty/etc foam grips.
I've started riding without gloves with these.
1 - 9 of 9 Posts
