Wait what? How much do you weigh? Unless you're running about 120psi your rebound is way too slow and causing the packing problemFork is not very supple off the top, tends to pack up even with compression being left wide open. Oddly the rebound doesn't bother me , though I tend to run it fully closed or 1-2 from closed. If I run it to far open it feels like crap and makes my arms/hands hurt after long descents .
Have tried running LSC in middle setting have heard some say that helps, did not help me. I've spent almost a year on the fork, run the gamut with settings nothing works to get me the ride I'm looking for.
Sent from #THELEGENDMTB using Tapatalk on an iPhone
Contact Michael at fullflow suspension Auburn,CA.I'm currently a 280lb rider, trying to find the best upgrade. Currently have a 2018 Fox 36 Fit4 Evol 170mm fork. Trying to figure out which would give the best ride and adjustment.
I've read good reviews from both setups but nothing specific for my weight so I'm looking for more insight .
Ok, that makes more sense now. Sorry if I missed your weight in the first postI weigh about 280lbs and yeah run about 120psi, good guess.
If I open it up it feels too chattery, it actually feels better to me slower.
Do you think I'm running to high psi and need to lower, then open up rebound? Suggestions? I'm willing to try something new just not sure where to begin.
I've had grip and grip2 and FIT4 with fractive tuning. The last option felt the best to me. Cycling dampers out of the fork is hardly the best test I wouldn't think.Grip2 has noticeably less sticktion then the Fit4. It is the gold standard of dampers right now. I have cycle both of them out of the fork. Fractive tune will not be better than a stock grip2 as the lower seal on the fit4 contributors the majority of the drag.
Cycling the damper out of the fork will provide zero information on the actual damping. We agree on that.I've had grip and grip2 and FIT4 with fractive tuning. The last option felt the best to me. Cycling dampers out of the fork is hardly the best test I wouldn't think.
If your spring is sub optimal it doesn't matter what the damper is doing.Just spent a good 53 minutes on the phone with Craig at Avalanche, I have a good understanding of where I need to go and what needs to be done. Unfortunately I'm really just to big of a rider to benefit from just a Luftkappe and Fractive tuning, a full damper setup it going to benefit me much better. Thank you all for your input.
