1 - 13 of 13 Posts
I'm noticing that it's near impssible to bottom my grip2 that came on my ripmo back in October 18. I'm running 15psi under recommendation, have and lsc are 4 clicks more open then rec'd, hsr and lsr are 4 clicks faster. I'm still only using about 75% travel max on steep chunky trail with step downs.
I remember reading something about grease in the air chamber affecting compression, does anyone have info on this and how to investigate?
Also, if anyone has seen a useful tuning guide that would be super helpful!
Here is a thread on this topic: https://forums.mtbr.com/shocks-suspension/excess-grease-fox-fork-negative-chambers-1068693.html
Basically, you need to remove the air shaft to check if this is the case.
Have you sent anything to flat properly? On a regular ride without big sends, I use around 140 of the 160 mm travel, but I do use up the full 160 when sending some bigger stuff. That said, I do run the fork in line with recommended air pressure.
Rollin 29s
Same story with mine on a Ripmo. It’s been pulled apart 3 times and is back in the shop this morning. The thick factory grease was removed and replaced with oil 2 services ago. I swapped in a 170mm air shaft to replace the stock 160. I tuned with a ShockWiz tuning module, and it said the fork was optimized with just 44psi. At the recommended 85 or 90psi for my weight (207 lbs), I’m barely using 60% of travel on chunky step down rides.
40 to 45psi gets me to using 95% but still never bottoming out.
I’m going to try an MRP or something aftermarket soon.
Keep in mind the FOX36 is a big bike fork. It needs to satisfy customers who do some seriously aggressive riding. It really comes alive at high speeds. I have a RC2 and find the same. Kept thinking it was harsh, but then it would amaze me how composed it was when I was hammering it. If I dialed out the compression and lowered the spring, it would suffer when ridden aggressively.
If you're quite light; you may benefit from getting the compression tune lowered by PUSH or Vorsprung.
Dude...
Why would you use any compression damping if your fork feels harsh? I would always suggest starting with no compression damping until you feel you need it.
Have you seen Mike's video on setting up the Grip2? It was super helpful on setting mine up
1 - 13 of 13 Posts
