Trying to diagnose an issue where I can feel and hear grinding or popping as I'm pedaling under load. It happens several times per revolution and feels like chain links not engaging 100%.
I can spin the pedals on a stand and no grinding, shifting is perfect. I can replicate the symptoms by holding the rear brake while moving the pedal on the stand. I also replicated the noise/feeling by laying the bike upside down and pedaling while holding the rear wheel.
I also pulled off my pedals and pushed on the crank arm, no change.
I recently replaced the wheelset on this bike running NX eagle. At first I thought it must be a defective freehub, swapped back to my old wheelset, grinding persisted.
I swapped out the chainring with a new spare I had lying around, no change.
So I've eliminated freehub, pedal bearings and chainring. 4 things left that could be causing the issue unless I'm missing something.
Chain
Cassette
Rd pulleys
Bottom bracket
I would think the chain is the most likely issue (I've removed, cleaned and relubed it with no difference) but the eagle drivetrain has done less than 100kms, I highly doubt the NX chain is that poorly built.
BB (XTR) has probably done closer to 800kms and apart from the frame is the oldest component on the bike. Could a worn BB cause a grinding, popping feeling/noise several times per revolution?
Chain
Cassette
Rd pulleys
Bottom bracket
