1 - 11 of 11 Posts
that is what's left of the outer bearing on a dt240 freehub. just the inner and outer races remain. dust cover and ball bearings are nowhere to be found. my question; did singlespeeding cause this? was it overtightening the rear axle? I guess this is why I've been struggling to maintain chain tension. I may try to press new bearings into this freehub and save it but I've already ordered a replacement with a new end cap. Just wondering if anyone has seen failures like this, thanks!
Do you know what kind of mileage the freehub had on it?
I have trouble wearing out these bearings at all, nevermind like you have here! I HAVE worn out the endcaps before (specifically the o-ring that holds everything together). Once that o-ring starts to go I could see contamination pick up and spiral from there maybe?
psycho cyclo addict
The bearings in DT hubs may be negatively impacted/stressed if you over tighten the skewer/axle/bolts in the dropout.
I generally tighten just enough to keep it from rattling loose.
Wanna ride bikes?
What frame is this used in? If the rear wheel is slipping you may be over tightening the hub to try to correct it. Is there a tension adjustment screw on the dropout, or is it sliders? Got a pic?
1 - 11 of 11 Posts
