1 - 20 of 25 Posts
I don't do PC
Gonna pickup a used Gran Mal and it comes with a 9.5x3" shock, I understand that the lev ratio will change between the shock mounts on the linkage but will the lev ratio also change between the chainstay positions? Probably run it in the middle setting and use both travel options, trying to fiqure out the spring wt I need, thx!
I don't do PC
Discussion Starter · #3 ·
Yeah I've seen that, thx, guess I wasn't sure if the change in travel between the chainstay pos's would affect the lev ratio and spring wt I need, seems like it's just a function of geometry change which is shortening the stroke of the shock.
Just roll it......
RR, the two positions on the rockers will change the travel/rate and you can firm it up if you run it on the upper position or you can run it softer in the lower setting. It's not a huge difference, but it does make a difference, imo.
The chainstay positions will have a slight effect on travel as well, but more so on the BB height and head angle. If you run the 9.5 x 3" stroke shock, however, you limit your options with the chainstay option....you can't run it in the further hole in the back or your tire will hit the seattube. This was part of the reason I went to a 8.75 x 2.75 CCDB this year (although, we'll see how well that works).
As for the right spring...what's your weight with gear? I'm about 170 with gear and run a 300# spring with 35% sag. I could probably run a 350, but this is my big bike after all so I like the extra plushness.
Cheers,
EB
Trophy Husband
RR
Good choice in frame. Much better than the "other" frame you were considering....which I ended up selling anyway :rolleyes: .
cheers
I don't do PC
Discussion Starter · #7 · (Edited)
Thx eb, this is the shock(Manitou 4way) that comes with the frame so I'm gonna give it a try, might try something else later tho, I saw your original post about the smaller shock length, makes sense.
I'm around 220 probably w/gear, the seller is around 20lbs lighter and was running a 400. My calc's are not coming up with the same spring wts you and the seller use(at your weights) so that's why I'm asking about the right lev ratio to use to figure the spring I need.
From the site I'm getting 8.2" and 7" travel in middle CS pos(probably the geo I want) which makes for 2.7 and 2.3 lev ratios, so that's a 500 or 600lb spring??
I don't do PC
Discussion Starter · #8 ·
geolover said:
RR
cheers
Oh well, sure looked nice, there were several others as well BTW, I was kinda wondering why there were 3-4 for sale already but after talking to you it made sense. What are you going with as a replacement?
Trophy Husband
Got a killer deal on one of these: LINKY
I don't do PC
Discussion Starter · #10 ·
Very nice, would of considered one of those too but they are hard to find used, guess that's a good sign. I scored a Boxxer as well, looking forward to this build!
rroeder - At 200lbs geared I had a #450 on my Mal in the long travel 8.2" setting. It was super plush on upper Whistler but soft on the lower mountain. Would have been able to run a #500 easy. I think #550 would be a good starting point for you for a good all around spring.
I don't do PC
Discussion Starter · #12 ·
Thx, I will try a 550 and see how it feels
Hisforever
gran Mal? sheeeesh, with the Go ride frame deals right now i figured you would get one of them Highlines!
Its definetly not a Ghey bike
I don't do PC
Discussion Starter · #16 ·
What are you talking about?, Highlines are the gheyest bike ever!
I don't do PC
Discussion Starter · #17 ·
FoShizzle said:
p.s. what color I9s are you going to run?
Purple and green with Zebra striped polka dots
You 2 bored since there are no juicy emails from the haters?
Fo' Bidniz in da haus
seriously though....thats a pretty psick bike.
and plus, doesnt ebextreme ride a transition? he is totally dreamy!
I don't do PC
Discussion Starter · #20 ·
Finally got her finished!
Can't wait to get out on it, hopefully break it in this week. BTW, I went with the 550 spring and it feels firm, should be the right spring weight for my size tho. I set it up with a front der for some local stuff. 44.7lbs.
1 - 20 of 25 Posts
