njhcx4xlife said:
I can't find a definitive answer in the transition website about running a front der. on a gran mal. Anyone know if it is possible and if it is then what pull and swing der you would use. I would thing you need to use the saint since it 83mm bb but I'm not even sure it is possible.
The saint will work better because of the longer throw, but I'm running a LX with no issues with 2 chainrings and a bashguard. Top Pull - Bottom swing, btw.
As Misctwo said, you will need an add on cable stop and cable guides to run a front der. if you have an '06.
The '07's will be coming with a cable stop and guides welded onto the frame. If you're buying your frame from Transition, they'll sell you a Problem Solver cable stop for cheap and it takes 5 minutes to install it. I also run 2 stick on cable guides along my top tube (slightly underneath), and one on top of the cable stop and run full length cable housing through those (see pic below). Of course, if you get an '07, you'll be good to go.
One other tip. When you install your front derailleur, you'll want to ensure that it's high enough on the seattube that it doesn't hit the chainstay upon full compression. I installed my derailleur where I thought it needed to be and then removed the spring off my shock and fully compressed the backend to make sure there wasn't any interference upon bottom out.
Cheers,
EBX
