1 - 8 of 8 Posts
got me a creak on my trek sounds like its coming from the bottom bracket it only creaks when i put strain on it so going up hills mostly can someone advise???or could it be the chainring bolts or even the splines on the isis drive??? i`m dying just to take it all apart and grease it all up but will i grease the wrong parts from them to come loose??? please advise..........:madman:
yeah, check all the stuff you said. also make sure the bottom bracket is tight and sometimes you have to grease the threads on the bottom bracket where it threads into the frame. best-o-luck! :cornut:
also, dont rule out the pedals!
Discussion Starter · #7 ·
yeah i greased it up and its perfect now next question why does the front wheel pull to the side its braking from when i pull it???? its a magura julie hydraulic disc brake and a mavic d321 front rim with a shimano 510 hub???
1 - 8 of 8 Posts
