1 - 20 of 27 Posts
Here's a project that I've been thinking about for quite a while and finally got it in the machine. So far it seems like it will work nicely. I ran out of time to get the light set up on it today but will get that done in the next couple days and if the weather permits, a shakedown ride. Whether or not this will become a "product" is tough to say. There are lots of variations in stem faceplates to try to work with.
RAKC
very nice vanc!!! your right, sadly there is SO MANY types of stems out there. Which Im guessing is why no one has attempted it. Definitely be an awesome addition, I may have you make me one after fatbike season is over for my fatbike (can be without my stem cap atm obviously). My 29er on the other hand would be a lot of hassle, RF Evolve stem with full bar wrap for carbon bars (my case RF Sixc bars). Want one for the fatty though, so if you end up with access to a Salsa stem before spring....
Discussion Starter · #4 ·
.....your right, sadly there is SO MANY types of stems out there. Which Im guessing is why no one has attempted it.
Yeah, out of 5 bikes in my garage, there would be 4 variations required to fit each. And that's just with 25.4mm bar diameter bars. Add the very popular 31.8 and the relatively new 35mm sizes in there and it just seems like pretty much every order would end up being customized to some extent.
Drinkin' the 29er KoolAid
Yeah, it would be a major hassle dealing with all the different stem types out there.
Hope had something similar for their light mount (not gopro compatible): Hope Vision Light Mount Stem Faceplate - $18.95 - Bike Parts 360
It would be interesting if one could come up with a way to piggyback onto the existing face plate bolts but I imagine even that would be complicated to achieve.
Yeah!
That's what I was thinking of doing. Small piece of angle aluminum, Some spacers to sit between the bracket and the bolt head seats, and two bolts long enough to go through the bracket and spacers.
Discussion Starter · #8 ·
.......Hope had something similar for their light mount (not gopro compatible): Hope Vision Light Mount Stem Faceplate - $18.95 - Bike Parts 360
The Hope faceplate mount and a faceplate mount by a Cosmoworks over on the DIY forum were what planted the seed of this idea in my head a few years ago.
That would be pretty easy to do though kind of low on the cool factor.
How do you make a piece like this? Is it all CNC? Do you have your own machine?
The only way you could make a product out of this is just to pick 2 or 3 popular stems from the current year and then make the plates just for those. Or you could sell the stem and plate as a kit.
Very nice work as usual.
Discussion Starter · #10 ·
Yes, this part, as well as my GoPro light adapters, are CNC machined from aluminum blocks. A part like the stem faceplate starts by being designed in a CAD software program. Once the design is good, the CAD model is used with a CAM software package to generate the cutter movements that will rough cut then finish cut the model's shape with different tools. The cutter paths are converted by a post-processor software to programs that the CNC machine controller uses. Then the cutters are setup in the machine. Material is fixtured in the machine. and the programs run to carve out the part.
Sorry for the long-winded explanation but maybe there are some readers that will be interested in how a machined part is made.
I do have my own CNC machine as well as a couple other metalworking machines. Keeps this old retired guy out of trouble (and off my bike more than I want).
Discussion Starter · #14 ·
Between last months record rain for our area and last weeks cold and bit of snow I managed a short ride. This mount worked great. I used to think my double o-ring mounting was pretty solid. This mount is better. It also puts the light just far enough forward that I get no glare when standing on climbs. I'm going to borrow a friends GoPro camera to make sure there are no fit issues for camera use.
As of now I can make these for 25.4mm bars with 2 bolt stems with 37mm and 39mm hole spacing. Hopefully soon I'll have a Thomson 4 bolt stem for 31.8mm bars to measure up and and make a faceplate for it.
Do you need a stem to borrow?
Discussion Starter · #16 ·
Thanks but no. Someone has ordered a faceplate and is supposed to be sending me the stem to match it to. Initially, this is how I'll do the faceplates. Faceplates for popular stems like Thomson will be "standards" and I'll keep them in stock after I make a couple and if it seems there is enough interest to justify it.
Oops I forgot I asked you this. I wasn't on this site much over the holidays. Anyway thanks for your explanation, it's much appreciated. I've been casually reading about CNC machines and people who build their own. It's something I'm considered trying to do somewhere down the line. I've seen some articles on building the step motor controllers with inexpensive Arduino/Raspberry Pi microcontrollers/computers. I'm going to mess around with those first. Eventually I would like to build my own lights and ditch the cheap Chinese ones. Well, I've probably derailed the thread somewhat. Sorry about that. Your mount looks awesome.
You know if you had one of those 3d scanners you could take anyone's stem faceplate and then add the gopro fins in your cad program.
Discussion Starter · #20 ·
Since it is my thread, I'll derail it further.
IMO if you want to get into CNC, just get out and find a decent shape late 80s-mid 90s Japanese or Taiwanese machine. Small ones can often be had for $2500-$4000. You'll have to look through a fair amount of junk, but after a while you'll run onto something decent. Sure, it will be dirty and the paint bad, but at the core it will be solid. The home-builts are a money and time pit and the end result often is buggy and unreliable.
1 - 20 of 27 Posts
