Are you looking for a self-contained light or is a external battery OK? Price range?
Mole
Mole
Self contained, this light doesn't have to be super powerful (500 to 1000lumens should be fine) so I was hoping to stay around $100 or less.Are you looking for a self-contained light or is a external battery OK? Price range?
Mole
I actually have the outbound setup for my own trail bike. It is great on the trail. This light would live full time on a flat bar gravel bike (I'm actually building for someone else) that would ride like 80/20 road/singletrack. I think the outbound is a little overkill for it and the beam isn't great on the road though this light would be more to "be seen" anyway.I used an Outbound Trail before I got the Evo, and it work[ed] great. I am eagerly awaiting them making a gopro mounting lug for it, since I also use a stem-mounted gopro spline, and would like to go back to it.
If you liked the Flux(?), you'll love the light pattern of the Outbound stuff.
Maybe consider one of the M99 lights from Supernova; it needs a 10mm lug (dynamo light standard), though. Not too hard to adapt from one to the other; you can remove the middle spline, or install an extender, that you remove the middle spline from. It is quite expensive, though.I actually have the outbound setup for my own trail bike. It is great on the trail. This light would live full time on a flat bar gravel bike (I'm actually building for someone else) that would ride like 80/20 road/singletrack. I think the outbound is a little overkill for it and the beam isn't great on the road though this light would be more to "be seen" anyway.
I make 10mm lug to GoPro adapters. If interested send a PM or email to the link on the webpage in my sig line.Maybe consider one of the M99 lights from Supernova; it needs a 10mm lug (dynamo light standard), though. Not too hard to adapt from one to the other; you can remove the middle spline, or install an extender, that you remove the middle spline from. It is quite expensive, though.
Square lights that have directed-beam patterns are not really easy to come by.
For what it's worth: many lower-powered e-bike headlights can be run from a battery (albeit, with no control over light levels/requiring a DIY switch/pack, typically), and share the same 10mm mounting lug.
