1 - 4 of 4 Posts
Mr. Knowitall
Hi
I am about to build my first high quality set of wheels based on Chris King ISO Discs, and I am a bit confused on which rims to go for. I am 75kg+ and ride a Yeti 575 '08 with TALAS 32. Weight is an issue as well as sufficient strengt.
I plan to lace my wheels using DT Supercomps (on recommendation from experienced local wheelbuilder) and aluminium nipples.
I have these rims in mind (most expensive top):
DT 4.2D (400g)
NoTubes ZTR Arch (420g)
Mavic XM719 (460g)
Syncros FLR DS23 (440g)
The Arch is tempting, but it does not have eyelets, and I have heard that eyeletless wheels are not too good with alu-nipples.
Do anyone have some view on these rims? I am not the most aggressive trail rider, so heavier rims are not interesting nor necessary.
Get your freak on!
Out of those i'd say the Arch. They are the most easy (and lightest) to use tubeless and they have been proven to be a very durable rim (but all the others in your list have aswell).
I would not worry about the lack of eyelets, the Alloy nipples will work just fine in this rim if built with correct tension.
hssp said:
Hi
DT 4.2D (400g)
Mavic XM719 (460g)
You weigh about the same as I do, I have a set of Hadley's laced to DT 5.1s for
my trail bike. I think they weight 450g, and have been very good rims.
OTOH, I won't use aluminum nipples anymore, after a couple of years of hard riding, I've had numerous breaks at the nipple, and have since replaced with brass.
Mr. Knowitall
Discussion Starter · #4 ·
I think you ride a bit harder than me:) And the 5.1s are a bit too heavy for my taste (500 g). I hope to land on about 1700 grams tops or a bit less. The Arch sound tempting as I am going tubeless anyway. I have been running my machine built Syncros FLR DS23s on XT hubs since July, and they are still true. And white;) Is there any reason why I should not lace my new hubs to these (or similar new) rims?
1 - 4 of 4 Posts
