You didnt have it soaking in cleaner/degreaser for a period of time did you? If you leave a sram chain soaking for an extended period it swells the bushing material and causes it to fail in multiple locations......cake96861 said:What are some good chains (8sd) for dirtjumping, DH, FR? I just broke my new SRAM, I have no idea how but two of the links were twisted??? Havent dropped it or anything.
As stated earlier Sram is still probably your best bet.cake96861 said:Im not sure about the length, ill check. No degreaser, just simple green, lots of water to rinse and then tri lube....anyway im still in need of a new chain. I saw sachs, shim, and sram. Which one of the three are the best for durability.....
Ditto on the Sram006_007 said:As stated earlier Sram is still probably your best bet.
