I don't have these on my bike yet, but I test rode a bike with them and REALLY like them! I will most likely get a pair for myself soon.Rhys05 said:I've got some Ergon GP-1's, they may take a bit of adjustment, but I like them so far...
how did you have a terrible experience without even using them? you might have been able to get a refund...if you didn't slice em off.mx_599 said:I like Oury.
I tried ESI grips at the recommendation of others and had a terrible experience with them. In the end I sliced them off with a razor blade. They were ever used for even one ride. I want to to see if ESI will refund my money. They were close to $20...and never used. :madman:
c0ld said:Thanks for the great choices im gonna go and see if my LBS carries the ones you mentioned. So top picks would be Odi Lock-ons I really like how they look, or the ergon's they look kinda weird but they do look comfortable.
Do all grips are universal or do I have to look for a special fit for my bike?
Here is the one my bike comes with (Handlebar: GT Mtn Riser, 15 mm rise, 6061 heat treated, 31.8 mm clamp)
believe me, I am with you. I basically had to slice them off. I had the asymmetrical chunky ones.square said:how did you have a terrible experience without even using them? you might have been able to get a refund...if you didn't slice em off.
i have a cheap set of ritchey grips for now.
I love mine. They are simple, look good, provide good cushioning, and they stay in place. I do agree that they are harder to get on and off than most grips, but I like that. Most grips I have owned have slipped a little in position. Not these. I just removed one today to do some maintenance on a shifter. At first they were hard to get off, but I ended up sliding a screwdiver unde them, and pouring a shitload of alchol in, and they slid right off.mx_599 said:believe me, I am with you. I basically had to slice them off. I had the asymmetrical chunky ones.
major difficulty getting them on. even worse trying to get the fat part in the right spot. tried multiple tricks and "lube" solutions. nothing worked. to the point of getting blisters on my hands trying to manipulate them.
then, a change of componentry plans called for grip shift...:madman:
after all that, I attempted to get them off and it was not happening. razor...
to add insult to injury, the packaging claims easy on easy off. right. I might have been an isolated case...but they are not easy on easy off!
:thumbsup:
