Toby said:
But don't put sealant, Stans or home made in Kenda UST tires as it causes the layers of tire to seperate.
What UST Kenda tire did you have that problem with?
No problem here yet with the UST Nevegal on the back of my BLT, but the way this thing has knobs chipping and flaking off of it after only about a half dozen rides on it, I doubt it will last long enough to have casing separations with the Stans in it. It's not sticky rubber either. I have Maxxis sticky rubber tires on other bikes and on the front of that one that are not flaking apart as bad as this Kenda, and sticky rubber wears fast. Nevegals get good reviews, but so far not impressed with this UST 2.1 as a rear tire, no better than a 62a Larsen TT. I'll probably go back to a UST Ignitor since they have a 2.1 UST version listed now.
Yeah, I run Stans in all my tires, UST or not. Too many thorns around here not to. Never had a casing separation problem due to sealer that I know of, but had a few tire types that just do not seal with any sealer, gazillions of holes in the sidewalls kept leaking sealer and bleeding down. What fine quality products tires are when the casings are so porous that they were not designed to hold air, much less sealer.
I used to put Slime in DH tubes, but the only ones it would seal thorn holes in were the Hitchinson Green DH tubes. I found Stans works better in tubes too if you have to run tubes.
Cheers,
Dave
