Sweet! Thanks.
Dan, yah as you reach the end of each block, you can incorporate them into your program. At the end of tempo-add the tempo criss crosses, at the end of sweet spot add the sst criss-crosses. I wouldn't start out with them, but at the end of each block as fitness grows they are perfect to add inDan Gerous said:Interesting, I realized I already do it when doing long intervals on a trainer, I was more doing it to break the boredom though...
Jason, I'm starting my second base block, would it be a good idea to already apply that in my tempo intervals? My base, very generally speaking, goes a bit like this: Prep: resistance (done), Base 1: mostly Z2 (done), Base 2: tempo. Base 3: SweetSpot... I'll be doing XC, endurance and road races then cross...
That makes sense. Thanks.sprocketjockey9 said:Dan, yah as you reach the end of each block, you can incorporate them into your program. At the end of tempo-add the tempo criss crosses, at the end of sweet spot add the sst criss-crosses. I wouldn't start out with them, but at the end of each block as fitness grows they are perfect to add in
Yup, you got the jist of the interval down :thumbsup:Okie Dokie said:I hate to sound ignorant but if you could please help with some clarification I would appreciate it.
So 3 x10 ON 10 min off b/w 217-258w with 1 min at 285 watts at 2, 6, 9 min
means that the interval is 10 minutes long with a cross over to threshold at 2, 6, 9 for 1 min right? And 10 min off between intervals?
As I do not have a power meter but my LT is around 180hr can you give me an idea as to where I would want my HR for the interval?
thx and again sorry for such basic questions but I am trying to learn.
Your workout sounds reasonable. But you can do one of 2 things; especially if able to do it without issue for an hour. Shorten the spacing between LT work and/or increase your tempo efforts up towards sweet-spot efforts. How did the efforts look over the gist of the hour, was power dropping off at the end of the ride, was it sustainable,etc??nomit said:bump. looking to incorporate this into my training to mix it up from 2x20s and SST rides.
have 2hrs to work with. would you recommend spreading the intervals out over a longer period of time, doubling down the suggested workouts in the link (with perhaps an added rest day to prevent overtraining), or doing one of the suggested interval sessions and then maybe a hard tempo ride for the remaining 45 minutes?
for instance today i did 10 minutes mid-tempo (around 245 watts), then 2 minutes at LT (300 watts), 10 minutes tempo, 2 @ LT....and continued that for an hour, then did 15 minutes of easy spinning, and continued for another hour like the first hour. acceptable? or would you think closer spacing between hard efforts is more beneficial?
I don't disagree they can't be done hence the chart, my numbers were for predominately indoor rides.... Typically when you increase the time at SST, you're doing mostly freestlye sweet spot. Not too many out there that do 3 hours straight of sweet spot, but 3 hours inside of a mulit-hour ride is def feasible. :thumbsup:nomit said:last FTP test at the gym was 2 months ago. ended up doing around 280 watts iirc.
currently do 2x20 LT efforts at 300 watts, so i think i've progressed well since then.
i've also been skeptical of the gym bikes. but if nothing else they do seem consistent from one to the next, i'll have the same PE at the given wattages/levels, can do the same workout and feel the same way regardless of the bike. and if i use analyticcycling.com's power calculator thing, based off an outside hill climb at an LT effort, i come up with very similar numbers to what i do at the gym. just been trying to make the best of what i have to work with.
i also saw here... http://www.fascatcoaching.com/sweetspotpartdeux.html .... that sst rides should range from .5 to 3 hours, so that's why i haven't really stuck to doing them for just an hour.
