why would you want to go narrower than a 2.3? At this point, that's a gravel or pavement tire.
I think hardtails, especially, do well with wider tires like 2.6" to 3.0" wide. It's partly a comfort thing, but the big deal is that with more rubber deformation, you get more traction because the bike bounces off of stuff a little less. The narrower your tire, the less rubber there is to deform around roots/rocks, the more the bike is going to bounce off of stuff on the trails, and the sketchier the ride will be.
There are some folks who rode 3.0" tires for a long time and went narrower. I was riding a fatbike for several years and then "sized down" to a bike with 29x2.6" wheels/tires. You do get more supportive tires when you get narrower. This matters when pushing the bike hard into the corners. Too much tire deformation and the handling can get vague. Riding style seems to be a major component to this. The bigger the tire, the more exaggerated this can be. Another detraction from big tires is that they can bounce like a ball pretty easily under certain conditions. High speed, repetitively chattery type stuff. That's why I sold my fatbike. Fatbikes do great when going slow over nasty terrain. They're not bad when it's fast and fairly smooth. Fast and chattery - terrifying for me as the undamped bounce from the tires became a feedback loop.
I find 2.6" tires to be a bit of a happy medium where I have some extra volume to give a bit more deformation. But tires are still pretty supportive, at least if I buy tires with the heavier duty sidewall options. A friend of mine hasn't had good things to say about the 2.6" tires with supple xc sidewalls on our trails.
