1 - 11 of 11 Posts
I'll be going 1x9 soon with a truvativ stylo 1.1 up front. I'll be taking the FD and shifter off. Is there anything else I need to be doing during the change?
Will a chain guide of some sort prevent any problems with the chain slipping off? Is that even really a problem with a properly adjusted drivetrain?
Lastly, is there a need to shorten the chain at all after removing the large chainring?
Discussion Starter · #3 ·
The stylo already has a sort of bash guard but that jumpstop looks like a good idea.
What's the easiest way to figure out what seatpost diameter you have? I can't find what my bike is spec'd with. Which diameter would I have to measure to find out?
edit: Just found out I have a 27.2mm seatpost. Which size N-gear jumpstop would I be looking at?
organically fed
My seatpost is also 27.2 and I got the 1 1/4" Jumpstop.
The bottom of my seatpost clamp is stamped 31.6, the outside diameter of the seat tube, which is essentially a gnat's ass from 1.25".
Snowjnky McDreamy
I use a XT FD minus the shifter and cable. I adjusted the high and low so it cant move. It is light and it works well.
V-Shaped Rut
How does a 1x9 qualify as a single speed????!!!!!
Just kidding. :D
I lost my chain like crazy when I did my tracer 1x9. I solved the problem temporarily by jamming a piece of metal in the front deraileur so it performed the same function as the jump stop. I have now ordered a jump stop, should be here today actually.
this is an easy way to measure directly from n-gear. i used this method, and it worked fine.
Sizing
In most cases, the needed Jump Stop clamp size will be the same as the front derailleur clamp size. If there is no size stamped on the front derailleur, or there is no front derailleur, the easiest way to determine seat tube diameter is to cut a strip of paper 4 inches (100 mm) in length, and wrap it around the seat tube. If the ends overlap by more than a quarter inch (7mm), it's probably 1-1/8 (29mm). If the ends just barely meet, it's probably 1-1/4 (32mm). If the ends have a gap between them greater than a quarter inch (7mm), it's probably 1-3/8 (35mm).
1 - 11 of 11 Posts
