1 - 4 of 4 Posts
· Registered
I have one of those cheap Shimano Altus cranksets where all 3 chainrings are riveted together, and I need to know what is the easiest least expensive way to replace it with a single 36t in the middle and be able to have a bash on the outer. I have a 3x8 and I am yearning to go 1x9, I know all the other components I will need such as the cassette and chain and shifter, and I assumed i could just throw on a single 36t up front but when I inspected the chainrings I found that its the cheapo riveted style.
Ive found single speed cranksets online that I guess I could use with an MRP chain retention thingamadoo, but kinda throws the bashguard option out the window, is running a SS crankset on a 1x9 a bad idea? if so what are some cheap 3x bolted cranksets I could use? And could I just buy a spider by itself and use my old crank arms with a new unramped 36t ring?
Please help I am having trouble finding info on this matter.
Oh yeah, my bike is a 29er, sorry if this is posted in the wrong forum
· Registered
body9599 said:
you could always take a grinder to it...grind off the teeth on the outer ring to make a "bash guard" and take off as much of the granny gear as you can without weakening structure/rivets.
If you're trying to save money this is the way to go. However, I suggest getting a chain guide of some kind to prevent the chain dropping down to the granny gear.
1 - 4 of 4 Posts
