Air pressured seals are tighter, increase stiction. And spring rate of coil is linear, vs. progressive rate air chamber springs.ccm said:
I converted an earlier Marzocchi air fork (x-fly 100) to coil and the difference in ride was noticably more buttery and with less wallow.
I attribute the more buttery ride mainly to less seal friction, although that shock just had firm topout negative springs which didn't reduce the spring preload effect of air. Double air still has much more friction at the seals. And the less wallow of my converted air to coil, because of the more rapid spring rampup in mid travel (just below sag).
And the tires matter a lot too. Lower friction coil makes a smoother transition from the undamped air spring of tires. If changing to bigger volume tire, lighten up the shock and fork damping and reset only as firm as needed to match your conditions.
The newer high end slider anodizing or ceramic finishes are much less sticky as earlier models of air. The difference in stickiness is becoming very close between air and coil. And to some degree the new firmer speed-sensitive damping compensates for the deeper rampup of air spring action. And many bikes are now designed with rapidly digressive rising or falling rate shock linkage leverage for better adapting air rear shock' rising rate spring action; so coil can feel too firm, especially when combined with platform valving.
It's getting close to the point where the only advantages of coil is the greater reliability and lack of frequent air spring pressure checking.
It's easier to sell air shocked bikes out the door to anyone. Coil has to be over sprung for lighter riders to be able to sell to heavier riders of the same frame fit.
In the long run coil is more fine tunable, always for forks, and usually for the rear if the rear shock linkage is not very digressive in leverage rate. But it takes longer to get sorted for each rider, often costing a few somewhat costly spring changes.
F1, MotoGP, MotoX, etc all use coil springs for suspension. They would use air springs if there was a performance advantage. F1 and some MotoGP bikes do use air for valve springs, titanium coil is too heavy to react fast enough for the revs used now.
- ray
