Does someone on your holiday list prefer to ride their bike rather than drive? Do they cherish the long ride to work and the commute home? Well, we have a handpicked guide to help you find the perfect gift for the commuter on your list. Commuting by bicycle takes guts and some very special gear that can put up with the rigors of day in day out abuse. Gear like; Fenders to keep you dry, a lock to keep the bike safe, a light to be seen and see, and bike wash to keep that machine clean and much more. So dive in and find the best gifts for the bike commuter on your list and maybe something for yourself!
Want more gift ideas?
SKS COMMUTER II FENDER SET
It's probably pretty obvious from the name that SKS designed their Commuter II fenders with commuters in mind. The Commuter II is an economical fender set that is built to withstand daily use. This classy set of fenders attach via sturdy stainless steel stays and are easily mounted with the included hardware. Sold as a set (front and rear fender).
SPECIALIZED FLUX 850 HEADLIGHT
There are two types of lights in the bike world: lights so riders can be seen, and lights so riders can see. The Specialized Flux 850 Helmet Headlight is an ultra-bright headlight that uses two different LEDs under dedicated optics, which combine to make the perfect beam of light. This allows riders to see both far and wide. The Flux 850 provides 180° of visibility. It is USB rechargeable and has 300 to 850 lumens of output. The Flux has four lighting modes to keep you visible at all hours of the day.
Garmin Varia RTL515 Radar Tail Light
It's a seatpost mounted radar and light that provides visible and audible alerts for vehicles approaching from behind up to 153 yards (140 meters) away. It's also a smart, integrated tail light that is visible in daylight from up to a mile away and integrates with most Garmin cycling head units. Check out our review of the Varia on Road Bike Review.
SPECIALIZED SAWTOOTH 2BLISS 700C TIRE
Tires are important to how well a bike rides. The Specialized Sawtooth 2Bliss 700c Tire is a top choice for adventure and gravel riders. It features a tread that hooks onto any surface. It has an Endurant casing that reinforces the sidewall and has the GRIPTON compound that offers excellent grip and control. The tread in the center is reinforced for high-mileage. Lastly, you can set these tires up tubeless so you can drop the tire pressure for a smoother ride and better traction in rough terrain.
ROCKYMOUNTS HENDRIX FOLDING LOCK
When you're commuting on your bike, space can be incredibly limited. If you only have a limited space to carry items with you, it becomes increasingly difficult to carry things like a lock with you. The RockyMounts Hendrix Folding Lock comes in a compact package that folds up easily and can be put in your back pocket or mounted on your frame using the included water bottle mount. It has hardened pins and 5mm thick steel links. It seamlessly wraps around your frame and secures your ride to anything from a bike rack to a post.
BLACKBURN BIG SWITCH RATCHET MULTI-TOOL
While you're out on the trails or the pavement, you should always have a multi-tool just in case you need to make an adjustment or something breaks. The Blackburn Big Switch Ratchet Multi-Tool is a high-performance ratcheting tool that makes on-the-go adjustments a breeze. It comes with extra-long 2.5 through 8mm Allen bits, T25 and T30 Torx, a Wayside chainbreaker, 0, 1, and 2 spoke wrenches, a disc-pad spreader, flathead, and a Presta valve core tool.
TOPEAK SMARTPHONE DRYBAG
Your phone is smart, but it has one weakness: water. Water is the Kryptonite to your iPhone's Superman. When the weather is nasty outside, but you still want to get your ride in, you'll want to get the Topeak Smartphone Drybag. It allows riders to be able to use their smartphone during longer rides. It features an integrated QuickClick mounting system that lets you mount or remove the drybag in seconds.
BELL DAILY MIPS LED HELMET
Whether you're cruising the bike paths, shredding the singletrack, or you're racing to the podium, you'll want to wear a helmet to protect your head. Helmets don't just provide impact protection, they also helmet funnel air to your head to keep you cooler, and provide sun and debris protection. The Bell Daily MIPS LED Helmet is made with a fusion in-mold polycarbonate shell to create a sturdier helmet. It features MIPS that helps reduce rotational forces that can result from certain impacts, an integrated LED rear light to help enhance visibility in low-light conditions, and an Ergo-Fit fit system for easy adjustments.
FINISH LINE Pro Care Bucket Kit
Daily commuting can be dirty work. The Finish Line Pro Care Bucket Kit includes everything you need to keep your bike running like new. The 6.0 kit includes 6 essential items that are necessary to keep your bike running clean and smooth and the 8.0 kit packs even more into the bucket!
Jenson USA Gift Card
Make gift-giving easy and guarantee the mountain biker in your life will get exactly what they want! JensonUSA gift cards never expire and can be used online, in our retail locations, and over the phone. You can choose a physical gift card, ideal for use as a stocking stuffer, or an E-gift card that's delivered the same day.
Still searching for the perfect gift?
Click here for more holiday gift ideas from Jenson USA.[/BUTTON]
