The VT is a pretty mushy suspension design that is only saved from bobbing by the platform rear shock. But it still squats heaps and hangs quite low in the back when climbing.jrm said:im riding a tracer now with a AVA propedal. Want more travel and the VT frame set with manitou swinger 3 is affordable. I'm 180 something if that matters. Comments...oh and thanks..
Didn't you used to ride an Azonic Saber? It's a classic Horst link which would have subtly better pedaling and braking than a monopivot VT with the same travel. With a platform coil it would be like a big hit Tracer. The list is $1300 for the frame and shock, adjustable 5 - 6 inch travel.jrm said:im riding a tracer now with a AVA propedal. Want more travel and the VT frame set with manitou swinger 3 is affordable. I'm 180 something if that matters. Comments...oh and thanks..
i had an AC and it was the same way...Dougal said:The VT is a pretty mushy suspension design that is only saved from bobbing by the platform rear shock. But it still squats heaps and hangs quite low in the back when climbing.
ill be damned if an quasi-lite or SB isnt looking real good right now..derby said:Didn't you used to ride an Azonic Saber? It's a classic Horst link which would have subtly better pedaling and braking than a monopivot VT with the same travel. With a platform coil it would be like a big hit Tracer. The list is $1300 for the frame and shock, adjustable 5 - 6 inch travel.
The VT should be pretty good with a Swinger shock, especially if you like firmer damping.
You might look for a test ride on a Marin Wolf Ridge, very advanced suspension design for longer travel XC and lighter freeride, light, stout, no bob seated pedaling without platform damping compromises, and no pedal kickback, adjustable 4 - 6 inch quick release adjustable travel, nice component packages.
- ray
