Sorry if my english is not very good but I am french so please take care
I would like to begin mtn biking but i don't know which bike take.
A friend already show me two bikes but I don't know which is the best. This bike are:
-Giant Terrago Disc (1.000 AUD)
Weight 14,51kg
Tally AluxX 6061 - FluidForm?
Fork SR SUNTOUR XCR-LO - clearance 100mm - manual blocking
Case of Pedals TRUVATIV Power Spline - 118x73
Pedals TRUVATIV IsolFlow - 44x32x22 - Power Spline
Chain KMC HG53 - 9 speeds
Play of direction TH TH888 - 1"1/8 a-headset conventional
Curve GIANT LB-A3 10 XL - 620mm - 6° - small channel 18mm - Ø25.4
Bracket GIANT ST-A3 10 XL - Ø31,8
Brakes front/back GIANT MPH 3 - hydraulics - disc 164mm
Rims/Hubs CR18 - 26"x1,5 - 32 holes - Presta/FORMULATED DC20/22 - 32 holes
Tires KENDA K849 - 26X1.95
Shifting tracks av/ar front: SHIMANO Deore - dual sweater - low collar rear Ø34,9/: SHIMANO Deore - 9 speeds - normal signal - large cover
Levers SHIMANO Deore - Rh throttle control lever - 9 speeds
Cassette SRAM PG950 - 11-34
Saddle WTB Speed V
Stem of saddle HL SP-232 - aluminium - Ø30,9 - 350mm
Extra Pedals VP VP992S - punts leisure - cage steel and body resin - 9/16
-Avanti Lightning (900 AUD)
Colours Deep Red
Size Options S-33cm,M-38cm,L-44cm,XL-50cm
Frame 7005 FormTech Alloy w/ 3 Main Tubes DB, Integrated Head Tube
Fork Manitou Axel Comp 100mm Travel
Front Derailleur Shimano Deore
Rear Derailleur Shimano LX
Brake Levers Shimano Deore BL-525 Hydraulic
Shifters Shimano Deore 27spd
Crankset Shimano FC-M440, 22-32-44
Brakes Shimano BR-M525 Hydraulic Disc
Hubs Shimano M-475 Alloy Disc
Cassette Shimano CS-HG50 11-32 9spd
Handlebars Alloy Riser 31.8mm
Handlebar Stem Alloy Ahead 31.8mm
Pedals Alloy Cage w/ Clips & Straps
Spokes Stainless Steel
Tyres Specialized Fast Trak Sport 26 x 2.0
Saddle Avanti Dual Density Sport
Seat Post Alloy 31.6mm Micro Adjust
Bottom Bracket Shimano BB-UN26 Cartridge
Headset Zero Stack 1-1/8"
Chain Shimano CN-HG53
So please answer me which bike would be the best between this two for riding really in mountain not just on track. And I would prefer a bike which is not specialised in jump.
thank you,
Inarius
Weight 14,51kg
Saddle WTB Speed V
Colours Deep Red
thank you,
Inarius
