I wouldn't jump straight to bent hanger.
I would just straight to "needs slight adjustment"...especially if it hasn't been adjusted since you put the XO's (with new cables presumably) on there this past fall.
Where does the ghost shift occur? When climbing, smooths, etc? Does it skip down to a lower cog, or up to a higher cog? Does it act like it's going to jump a little before it does, then if finally gives up the ghost (sorry, couldn't resist)? Does it tend to occur on the lower, middle, or top part of the cogset? Does it occur more when you're in the small, middle, or large chainring up front??
Answering all of these, we might be able to disagnos how you need to adjust your derailer. But 99.9999% probability your cable has just stretched a little and settled in, just needs a 1/2 turn tightening on the derailer, and all ills will be forgiven.
