Not entirely sure what the question is. If it is about the sealant at the bead, that should stop before long (like within a couple of minutes). If it continues longer than a couple minutes make sure you have enough sealant to do the job. Too little sealant and it won't be able to finish the job. If there is plenty of sealant swishing around when you shake the tire and it has continued to bleed out then you need to inspect the bead and your strip.
What sealant are you using?
