Not knowing what you are making it's kind of hard to comment usefully.
The short answer is you will need forced air cooling. Think something like a CPU heatsink and fan that is used in a computer. The CPU in a computer is usually at about that same heat level. You might consider using a CPU heatsink as a integral part of your light. Due to your location getting something from a local computer store might be a problem. If you have any broken computers that could be a source.
The airflow is key. A heatsink with no forced air flow would have to be huge to dissipate 55 watts. Many times the size you quote.
If the airflow is limited or intermittent a fan is almost a requirement. The small lights on this forum only work because they are normally moving. It might be a good idea to use a driver that turns down the power as the LEDs get hot.
