OK, hope you don't find my little experiment too foolish. You are blindfolded so you don't see what frame you are riding, ok no that's stupid, the frame is covered so you just don't see which brand/name it is. The 3 frames have the same fork (6" travel), same shock with similar travel (6") but not necessarily the same rear suspension design. You ride technical trails, steep ups and downs,...
1st frame has 66 Head Angle, 71.5 Seat Angle, 44.0 Wheel Base, 16.9 ChainStay, 22.2 Top Tube and 14.2 Bottom Bracket height.
2nd frame has 67.5 HA, 70.5 SA, 43.8 WB, 17.5 CS, 22.8 TT, 14.0 BB
3rd frame has 67.5 HA, 70 SA, 43.1 WB, 17.1 CS, 22.5 TT, 13.8 BB
The first frame is stable going downhill. The cockpit is short so you feel a bit over the front wheel. It is quite slack in front so it tackles the steep downhill relatively well. You really need to put your weight to the front on steep uphill because the front wheel lifts easily.
So, how do you think the second and third frame will feel like? Are those geometry different enough to make a difference or is it too close that it wont change a thing?
Thanks.
Thanks.
