hello to all you mountain bike gurus. I have a question. I've read some articles about wider rear spacing(for example 148, 157 ) and they all claim that the wider it is the more stiff the frame. On the 148 standard the stiffness comes only from the angle of the spokes to the rim but again someone wrote that wider rear hub results to wider pivot points to the frame thus making a stiffer frame overall.
Now, lets say that someone gets a full suspension fat bike with 197 rear hub, does this mean that its frame is a lot lot stiffer from anything out there? if so , than why doesn't all buy fat full suspension and replace the wheels with conventional ones , lets say 27.5x2.6 , and only having the hub different in order to complete the whole assembly. in general , due to lot wider hub spacing of a full suspension fat bike , does it make a stronger stiffer frame?
for all the above lets say that frame weight isn't an issue and that serious manufacturers start producing fine forks.
