My bottom bracket on my 2004 Gemini (6 months old) was loose, took it to my LBS for repair, but they could not get it apart no matter what they tried. LBS made 2 call to the factory tech support and they advised him to contact his local sales rep for frame replacement. Not the solution I wanted, but OK.
Here's the problem though.....LBS guy said they will replace just the front triangle, rear swing-arm not to be included. That just seems wrong to me. These 2 peices are the central part of my rig and have "worn in" together. If they are going to replace the frame (which is admirable), I think it should include the whole shooting match; front triangle AND swing arm.
I would appreciate your thoughts on this.
