1 - 6 of 6 Posts
I live in Southern California and am using non-UST Geax Sturdy's. I weigh 165 and come across a variety of terrain, which includes quite a few rocks. What front/rear tire pressures would you start out with as a baseline? How low would you dare to go?
Thanks.
Premium Member
Thanks.
2.1 or 2.25? In either case you need to pick a starting point based on what you use in your other tires. Then raise or lower the pressure by 2-4 psi until you find what works for you.
I like to use as little pressure as possible. If I am pinch flatting or feeling the tire squirm in the corners I have gone too low.
Discussion Starter · #3 ·
They are 2.25's on a Turner 5 Spot...
Let's just say that I never got the pressures worked out to my liking on my previous bike, so I'm starting from scratch. Do you have any starting recommendations?
Thanks.
Geax Sturdy's
I'm 162lbs and have the same tires (love them...). I ride all types of conditions and I can actually get away with about 28lbs front and 33lbs rear. I've even had the rear down to 28 but I think that's pushing it when you get into more rocky/rooty trails (might pinch flat).
Later...
Basura Blanca
Run my Sturdy 2.25 at 30 top 35 psi. I weigh 200# sans gear, ride some pretty rocky stuff, and I rarely flat.
- Joe
1 - 6 of 6 Posts
