Hi all you single speeders,
I am building up my first single speed, which is a blkmrkt mob( http://www.blackmarketbikes.com/mob.html ).
It seems like most of the single speeds on here are xc bikes, but hopefully you can all help me. I have a 36 tooth ring up front, and need to decide what to run in the back.
So; 26 inch wheels, 175 mm crankarms, 36 tooth front sprocket, and a dirtjump and street appropriate gear ratio. What size rear cog would you recommend? Right now, I am thinking 19,20, or 21 tooth. And for the record, I tend to run pretty low gearing, and just spin faster.
Thanks everyone.
EDIT: in case it matters, I am 5'11" ish and 165 pounds.
Thanks everyone.
