I've heard reports that people have managed to run these tubeless, but I tried and failed. Couldn't get the tire to seal up to the rim.
What rim are you using?-LightOn- said:I've heard reports that people have managed to run these tubeless, but I tried and failed. Couldn't get the tire to seal up to the rim.
Consider it your X-mas presentDylanGalaty said:Thanks Mayor. I should have done a search.
Dt x470 which aren't tubeless or ust rims. I tried the gorilla tape method with no success. Maybe it would have worked with either a stan's rim strip or the inner tube ghetto method.the mayor said:What rim are you using?
