Gauley Headwaters IMBA Epic - what gear?
1109 Views 3 Replies 2 Participants Last post by  farley
Ok, heading over to WVA this week and planing on riding at SnowShoe MTB park and doing the IMBA Epic at Gauley Headwaters. Has anyone ridden in this area on a SS? If so, any idea what gear? Thinking 32x20 or 34x20, just not sure how steep the climbs are. I understand this trail to be rough so throwing the suspension fork on with larger tires to make it alittle more comfortable!
MC
1 - 4 of 4 Posts
32:20 x 29"er
I've done some singlespeed riding in that area, as have two friends of mine who have worked as guides wiht ERTC. All on 29"ers. I used 32 X 20--and I think Craig and Joey did as well (though they're both much stronger that me!)
I think a 32:18 would give you the same ratio on a 26" wheel.
There's not as much climbing on that route as might think (don't get me wrong--there's plenty--I just thought there'd be more) You got through a couple of watersheds and climb the adjacent ridges, but a lot of the riding is along the ridgetops which are kind of flat. Technical as hell, but kind of flat.
I think you'll have fun. If you run into Joey Boyle (guide at ERTC--rides a yellow Vicious monolith) tell him Mac says "hi."
Cool...
Thanks for the gear recommendation.
So the Epic route is not tough from a climbing perspective...but very rocky and technical? How long did it take you to complete the 37 miles?
Thanks,
MC
8 hours or so. . .
Don't let me mislead you, there's certainly climbing, but you're right, it's the rocky and technical that makes this epic "epic."
It's been a few years, but if I remember correctly it took about eight hours. That's based on a shuttle to the starting point on top of Gauley Mtn. If you climb mine road from 219 that will add more time.
Also, when I did that ride, I was running gears. I've since ridden in that area on SS, but just not that particular route. So the gearing recommendation is likely to be more accuarate the the time estimate.
Have fun!
1 - 4 of 4 Posts
