I wouldn't be asking but I ran across an aliexpress item that goes under the name of "for Garmin Varia TL/RTL 510 smart radar bicycle Light back caver case with Li-ion Battery 361-00082-00 compatible Edge 25-1030".
The seller put some pictures that actually show the battery and the rear cover - could it be that it is really possible to take this thingy apart without destroying it?
I might not so much interested in the battery and a rear cover, but I would be really interested in removing the battery and adding a cable with a water resistant connector to a bigger battery.
Question is, how to take this thing apart without ruining its water resistance? I asked the seller and he said, "it is recommended that you send it to a professional repair shop and let the technicians replace it for you."
Did anyone try and succeed opening the thing up?
Did anyone run across any mention of the process?
