Okay, so my trusty dinosaur of a PC is on the fritz and I've got a new machine on the way to replace it. The new one is getting the latest and greatest hardware I can afford (because I like mapping so much, I've got a 28" widescreen HD monitor on the way so I can see more map coverage at once). Unfortunately, it looks like no single OS outshines another at the moment, so at least for now, it looks like I'm going to be running a multi-boot system. At minimum, I'll be using Vista Home Premium 64 bit and Ubuntu (because I want to learn to use Linux). I might end up throwing Leopard on, as well, just for giggles, and possibly even trusty old Win XP in case I have some dire software needs not handled by any of those other OSes.
Clearly, I know how all my software will work on XP, but I'm not sure about everything else. My GPS hardware includes a Garmin GPSMap 76CSx and a Garmin Rino 120. The 76 shouldn't have any problems as far as I can tell, but I dunno about the Rino. That one connects via serial port and to use it on the new machine, I'll have to get a USB adapter. That's the one I'm most curious about.
Also, I'm concerned about software compatibility with Vista x64. Some programs work, but some don't. I haven't heard anything from the wider GPS-user community about how programs like Mapsource, NG Topo!, Motionbased, or others work on that platform. I also use a program called MN DNR Garmin as well as ESRI's ArcGIS 8.0. It's an older version of their software that I just don't know about. If it doesn't work, I'm not quite so concerned, though, because I also use QGIS, which will at least work under Ubuntu, Leopard, and XP if it doesn't work under Vista x64.
Anyone have any clue on which programs, OSes, and receivers will play nice together?
