1 - 14 of 14 Posts
Riding or Drumming
Garmin has (3) programs for Mac that replace Mapsource: Map Manager, Map Install and Roadtrip. It's been a while since I installed this stuff so bear with me. I believe that Map Install converts your Garmin map CDs to Mac compatiblity and Map Manager installs them. Roadtrip mimics the functions of Mapsource in terms of viewing maps, waypoints, routes, etc.
It's still a work-in-progress for Garmin but consideing they've had NO Mac software, it's a start.
Honestly, I only use Ascent for my Edge 305 data, no Garmin software...
Discussion Starter · #7 ·
I already know the problem. I download the RoadTrip (this is better than MapSource) but it doesn’t appear the box to choose what maps I want to show. So it only shows the original maps and can't chose the Citynavigator. I costume the toolbox and know it's working fine.
Meanwhile I'm working on Mac with MacGPS Pro (not very good) for military maps, with RoadTrip and online with GPSies with is a great program.
At Pc with CompeGPS (previously OziExplorer but the CompeGPS is much better) for military maps, MapSource and GPSies.
Surfas said:
I already know the problem. I download the RoadTrip (this is better than MapSource) but it doesn't appear the box to choose what maps I want to show. So it only shows the original maps and can't chose the Citynavigator.
Don't you have a box at the right had side to pick the map you want to view?
mac/garmin?
I just bought a garmin 60 series. The software that it came with says pc compatible only, no mac. However, there is a program on my macbook called bootcamp, where you can partition your harddrive and install windows xp or vista. I ran xp for a while and it worked fine. Although, you do have to use virus protection once you partition to run windows on a macbook, which sucks. I wonder if this partitionioning of my hd, which is fairly easy to do and undo is worth it or if there is better gps software for a mac?
GeoMan
There's plenty of Mac programs for using your Garmin GPS.
Take a look at our "links" page. Go to www.geomangear.com, scroll to the bottom of the home page and click on "GeoMan's GPS Links". Look around.
Ascent is one that comes to mind that is easy and used by many. Support and feedback have been excellent.
Let us know what you find.
thanks geoman
Hey thanks I appreciate it. I'm a newb w gps and am going to use it a lot this season. Luckily REI has a basics of gps course on the 12th. I will post my success if it turns out that way!
CCK
Garmin Hell and the Mac.
Garmin......Oh, how I hate theeeeee.
I used to use bootcamp and the Garmin software under windows on the Mac. I took boot camp off and now I use road trip.
The easiest way to get your PC maps is to get a 6 pack of good beer, call up a PC friend, go over and install Map Source on their PC. Install your maps and then download the converting software from Garmin. Convert and burn the maps into a Mac format. Give your friend the beer for taking up 2-3 hours of his time.
Go home and install the mac maps.
http://www8.garmin.com/manuals/MapSource_MigratingGarminMapProductsfromWindowstoMacComputers.pdf
ken
SpoK Werks Handmade Goods
I talked to Garmin support Stateside a couple of weeks ago (because Garmin Germany doesn't return your emails). Anyway, they were very helpful even though I was trying to install a Germany based topo map. At that time, they told me that much of the new Garmin software will be OSX compatible. Not sure how much that helps you at this point. I fight with my old G4 laptop and my iMac constantly as I don't want Windows on the new iMac. It works sometimes and not others. Good luck!
1 - 14 of 14 Posts
