1 - 13 of 13 Posts
Wondering if my 530 is messed up or is this issue is common?
I run my setting @ auto zoom off, but as soon as I slow down, the 530 zooms out anyway. It’s super annoying. It doesn’t matter if I run the map in 3D view or bird view. It got a little better after the previous firmware update but it still happens. And no, it doesn’t matter if I set the zoom manually, it still zooms out automatically if I slow down too much.
I believe I witnessed the map changing zoom a week ago while I'm on 4.10.
I wasn't really using the map, it was still enabled from a test a week earlier. But I believe it did still zoom out when I'd stop.
If I remember to enable the map again I can check it tomorrow.
Discussion Starter · #7 ·
Thanks! I think it wanted to update the firmware this Tuesday so perhaps they finally fixed it. I'll be riding tomorrow so will make sure it's updated before the ride.
Discussion Starter · #8 ·
"Update v 4.1:
Fixed an issue where the map zoom and orientation were not properly returning to their original values after the ForkSight page was displayed in a Mountain activity."
- Perhaps that's it, I've been wondering about that Forksite feature, haven't had any use of it, perhaps it's possible to turn "forksite off".
Edit: Well, perhaps I should have read it all...
  • Added the ability to disable the ForkSight page that appears when you stop during a Mountain activity.
Maybe it is 'updated'.
I started to record an activity and walked though my house and would stop -map didn't change. However, not sure I moved enough, auto-pause never kicked in when I stopped moving around.
Edit: A ride down the street didn't change the zoom level. Autozoom is off, I didn't think to switch it on and try again. Maybe the update did in fact stop that little quirk.
I thought for sure it was still zooming out on a previous ride, guess not.
Discussion Starter · #10 ·
The Edge is running v3.5 for some strange reason. It says there’s no update available. I have restarted it several times so perhaps it’s because I’m running it in Swedish, not English.
The Edge is running v3.5 for some strange reason. It says there's no update available. I have restarted it several times so perhaps it's because I'm running it in Swedish, not English.
USB Connect it to a computer running Garmin Express. That program will search for any available updates. I always update devices using wires and not over the air.
1 - 13 of 13 Posts
