Last thought
GeoMan,
It is obvious that you like the device and so do I, so don't take my comments as bashing the deveice. BUt, my the calorie counting is NOT limited to my device. It is an inherent flaw in the way the device calculates calories. Until Garmin decides to spend a litle more time (to their credit it no longer calculates calories higher when going down hill and coasting than riding pushing uphill) I will consider this a drawback to an otherwise good unit.
Just don't let your selling of the unit cloud the fact that the software and calculation of calories still does not come close to reality. I suggest you go for a 1.5 hr ride at 90% Max HR on a mountain bike but keep your speed below 12 MPH, then go on a 1.5 hr ride on a road bike with HR at 70-75% max and avg speed of 20 MPH and you will see that the calories are almost the same, ususally the road bike ride gets calculated a little higher. This is just plain wrong. Garmin should factor HR more into the calorie calc. as it appears that they are focusing on speed more now.
Given that the unit asks for user age, Max HR, bike weight etc in the set-up you would thnk that they would use this a little better in the calcs.
So remember, this is not an issue with my unit, it is the way the software is designed so the results are repeatable on any unit.
