When syncing the Garmin 510 with an iPhone 6 running IOS 9.0.1 and Garmin Connect, the bluetooth pairing occurs and Connect displays "syncing with unit" or whatever, as it usually does, but then a second later that goes away and it apparently doesn't pull over the latest ride.
The two reasons I upgraded to the 510 from the 500 were improved GPS accuracy, which it has, and the bluetooth feature, which for the past month has not worked at all.
Am I the only one? Do I have a defective unit? Garmin has not been responsive.
