1 - 20 of 47 Posts
I am moving to a house with a standard two car garage and I need find a way to fit in two cars, six bikes and all the normal garage junk :confused: In my current garage I am using these front wheel hangers ( http://www.pedalpushersonline.com/?CID=645 ) which work well but the bikes takes up a lot of space towards the cars. IMO, this isn't an ideal way to store the bikes and there must be a better method!
Has anyone found a better solution that is very space-efficient? How about hanging the bikes flat against the garage walls? Are there hooks available to do this?
Any suggestion would be greatly appreciated! :)
wannabe corporate shill
I don't know how small your garage is(or how big your cars are), but I use the standard bicycle hooks from Home Depot. They cost a whopping $.89 each, and work just fine. The bike hangs upside down and doesn't take up much room at all.
Super Moderator
When its non riding season, I used the two wheel hooks. Then I rotated the bike horizontal (fitting the bars between the joists). I then installed a third hook to grab the seat tube.Of course the hook is rotated to an "non grab postion" and the bike is swung up, and then I rotate the hook back to grab the seat tube...Are you visualing this?
Tony
We used to hang our FS bikes from the ceiling (as we did in the old days when all we had was road bikes), but my husband has read that you shouldn't hang FS bikes from one wheel. I'm guessing that you shouldn't hang them from the wheels at all, which make the idea of hanging them from the frame/seatpost sound better. Maybe you could buy some inexpensive racks just to mount them to the wall! Luckily our basement is big enough that we can park our 4 bikes anywhere there's a space. We have a carport for the cars, although it's not big enough for all 3. We DO have our priorities 'though. We glassed in the old carport for a hot tub.
Before you start making cracks about "lotsaballs soup," our tub is clean! If it doesn't look sparklingly clear, we change the water. Ain't nothin' better than a soak in the tub after a chilly ride.:D
Catherine
Fo' Bidniz in da haus
what i was gonna say....but i think R332 is in Canda, no? I live in Southern California and have a 3 car garage and dont even park the cars inside. Given the climate, it is not a problem here for my wife to load up the kids in the car outside.
My rack
This is what I am currently using in my garage. It holds my 4 most used bikes with quick access while the other bikes are hanging from regular hooks. This setup alows for sloping top tube bikes because it is supported at the wheels and not the frame. I've always planned on making it a little better looking but it works just fine I have never gotten around to it.
anyone tried this rack setup? Heck its only 29 bucks....
http://www.homeorganizershops.com/SS45020.html
I dont know how good / stable it is but i need somthing like this for my bikes. Ive collected too many this past year.
Has anyone used one of these? It doesnt appear to mount a the top or bottom. It is just free standing from what i can tell....but for that price i wouldnt expect much.
MTB Rider
I drive an Altima ...
I drive an Altima and my two bikes hange upside down right above my car on big "superhooks" that I got at Home Depot. My spare tires and wheels also hang from the ceiling,
My husband told me that he was thinking about using some roundstock wood padded with neoprene to hang our bikes in the basement. He is amazing at creating things out of nothing but scraps. He built a rack for storing paddling gear and three boats, in about two hours, just from ideas he came up with. I have no idea how he plans to affix them to the studs, but I know he can!
In that picture of the 4 bikes hanging in the basement...all have no suspension, and funky downturned handlebars; what kinda torture are you into?;)
Catherine
I am currently working on some brackets make out of $1 shelf brackets, 3/4 pvc and some pipe insulation on my living room floor while watching nascar. That combination right there may prove i may be on to something.
i am using the pvc to extend the regular brackets with 3/4 PVC and some hose clamps. The brakets will mount to 2x4s that are then mounted to the wall in the garage. This will allow for one bike to be mounted to the wall above my other bike (which will probably just be on the floor.
The brackets will be mounted and spaced so that the bike rests on the headset (in front of the head tube) and underneath the front of the seat.
It should work pretty well but i wont know until i get them on the wall. At the moment i am lacking mounting hardware to put them on the wall . I will probably pick that up later in the week and get them up on the wall. Ill take pics once i am done.
Home Depot hooks to the back wheel, hook mounted into the rafter. I figure if the bike can handle me and gravity then sub-30 pounds pulling on a wheel will not hurt it. Got 4 bikes hanging this way, with a variety of forks/shocks.
Discussion Starter · #19 ·
Does anyone have any good ideas to add to this thread? I am finally getting everything moved into my garage and I now need to store six bikes, two cars, tool and other assorted crap in a standard double garage :madman:
Photos of garage set-ups would be great :thumbsup:
1 - 20 of 47 Posts
