I recently bent a rotor in a minor stack and after reading all the posts on mtbr about just how great the Galfer stuff is, I decided to buy a set of 6" wavy rotors and pads for my Juicy sevens. The result? They pads modulate at slow speeds better than Avid pads, but lack the power of the Avid setup. Compounding this lack of power is that the rotor heats up chronically on even mid length decents, causing bad brake fade and a change in lever feel. I've never had the Avid setup anywhere near that hot before (rotors temporaraly discoloured and you could smell them). Meanwhile, the pads have worn a hole in the centre (I presume this is a wear indicator, as if one is needed), despite having had reletively little use and still being 75% of their original thickness.
In short I think they're a very poor replacement. I have switched back to polygon rotors and avid pads, which despite the caning they receive on this site I think are well designed and work very well if broken in properly and looked after.
Anyone else experienced this?
