Following up from my comments on this thread:
I have done some more exploring on the North side of Copper Basin (mostly because it is in my backyard and because I can't ride the awesome 305 every day).
332 from copper basin rd to 51: awesome singletrack, rideable both directions and in the wet. The sharlot maps show a couple branch offs, but I have not been able to find them.
51 from 332 intersection to 322: not bad at all for a fireroad - goes straight up and then straight down. Very loose which makes the climbing a little tough and makes the decent a touch sketchy. It is rideable in the wet - but it sure is wet and after the little bit of snow up there, it stays wet. For a bit of it you are basically riding on a stream. Basically though it is a connector trail that will give you a couple grins.
391/9401j from 51 to Copper Basin: not much reson to do this fun bit of singletrack unless you are doing small loops like I sometimes do from the house. The very end near copper basin is basically a hike a bike over railroad ties for 15feet or so - either direction (though I bet you downhillers could go down it). There is a pretty deep creek crossing right now so I am waiting for it to go down a bit. There is a "gate" in the middle that is an annoying mess of barbedwire. A lot of the time, it is down and I just keep it that way because it is rediculously difficult to put it back up.
321 from 51 to 232: this is fairly short, but it is a bit of fun. The big issue is the stream crossing. I was barely able to cross it on tues, but just after the rains I couldn't cross it. I turned on to 323, but it would be interesting to see what it does past that intersection - anybody know?
323 from 321 to 326: ick!! time to update the sharlott map - it is NOT a singletrack (as it's green color would indicate) - it starts out as a brutally steep and loose fireroad and then, at the flat part, morphs into a nasty logging road - super wide with huge mud puddles that you have to ride through. Ride this only if you have to...
326 from 323 to 373A: again - not singletrack. pretty boring, but not as bad as 323. I was trying to find the connection to 332 but I couldn't. It is real easy to get lost up here as the fireroads generally don't have signs.
387 from 51 to the road (forget the name): This one starts out as being bike legal, but then, in the middle is hiking only. Not much of a loss for me though - the first part is boring and really loose and the off limits part is only rideable going down and then only if you are a hard core huckster...
I am hoping that others can add to this info...
