Back in 2017, I decided to have a custom titanium rigid 29+ singlespeed built. After emailing numerous builders, I decided on Funk. They answered my questions quickly and thoroughly, while others either didn't respond, were slow to respond, or just sent a generic reply. Since then, that communication and customer service has not wavered when dealing with minor issues, a race face crank failure, and discussions on a new bike. While their frames can be expensive, I place high value on customer service, and Funk has the best of any company I've ever dealt with.
After a couple thousand enjoyable miles on my rigid bike, I ended up racing it instead of my old full suspension in a Super D. I had no issues in my 3 practice runs, but a mistake in the race resulted in a badly cut knee, chipped knee cap, broken wrist, broken shoulder, chipped elbow, and a severed ulnar nerve. I've mostly recovered but due to nerve damage I've lost a lot of strength and dexterity in my left hand. I can still ride a rigid bike, but for racing unfamiliar trails I decided it would be best to have the extra forgiveness of suspension.
After speaking with Funk about the LA Ruta, and seeing videos they made for me proving their suspension design can be used for singlespeed without a tensioner, I decided to have a bike built.
Their design uses a titanium flex plate and results in around 60mm of travel. This design has no linkages so it essentially requires no maintenance, it's totally silent, and there is minimal change in chain tension so it can be ran singlespeed.
I wanted a bike light and fast enough to be raced in xc and marathons, while also having the geo and strength for fun on rougher trails and small jumps. I also wanted clearance for 29x3" tires after experiencing their speed on my rigid bike. Here are some details I chose to meet all those requirements:
68 degree hta
Slightly longer tt than my rigid bike
Designed around a 120mm fox 34 sc
83mm bb
157 superboost rear spacing
Thicker walled downtube with S bend for extra bottle clearance.
Curved top tube so I have a comfortable place to sit when not riding lol
Additional bottle boss under downtube
35mm inner width rims
Hand brushed finish
Custom blasted graphics
Dual remote lockout for shock and fork
Seat in same position realitive to my other bike.
Reach the same as my other bike.
Total weight with pedals under 24 pounds with either 2.6 or 3.0 tires.
I now have a little over 100 miles on the bike including a 45 mile ride, numerous weekday group rides, and an xc race. Overall I'm extremely happy with the bike, and it's met or exceeded all of my expectations. I wasn't sure how 60mm would ride, but in general it soaks up rocks and roots very well and feels like riding a full suspension rather than a hardtail with some extra cushion. I thought the build might not quite work for racing, but it's proven to be fast while still being lots of fun on downhills.
The bike has been almost flawless as a singlespeed. I found that to keep the drive train silent, I have to run just a little less chain tension than normal, but other than that that there are no issues running singlespeed.
Tuning the suspension has taken a little more time than normal. Due to the flex plate, there is essentially an extra spring in the equation which does have an impact on sag, rebound, and compression.
I've found that I have to run lower pressure than previous bikes. The suspension is extremely smooth but less air is needed due to the flex plate.
Most companies avoid having the main pivot at the bottom bracket due to the suspension compressing under power. This is present on this bike, but with only 60mm of travel it's not a problem. After experimenting I've added more pressure and am not using much sag. When under power it essentially adds a little sag and everything feels as it should. I chose to go with a remote lockout on the rear shock for climbing out of the saddle. With that option the ability to adjust compression is lost. If I could do it over again, I'd consider staying with a normal shock for the ability to tune compression. When climbing out of the saddle with the suspension open, I really don't notice the rear moving nearly as much as I do the fork.
The suspension feels very linear and doesn't seem to ramp much. I don't bottom out all that often, but when I have time I plan to experiment with volume spacers. I currently love how the suspension feels and didn't want to mess things up with volume spacers before a race, but I think they will be needed to get the suspension dialed in.
I'm not sure how to describe it, but on medium sized downhill bumps, this bike seems to get hung up less than previous bikes. It just feels like more speed is maintained.
One of my favorite features is the ability to keep putting power down on rough sections of trails. Since most singlespeeds are hardtails, this is an area I've always felt like I lost time to full suspension bikes.
I also love the silence of the bike. There are no linkages, no moving tensioner or derailleur, and no chain slap. I've experienced this on rigid singlespeeds, but it truly surprised me on this bike.
Overall I'm very happy with the bike. The suspension has it's quirks, but if you're looking for a full suspension singlespeed, this is as good as it gets in my opinion
Sent from my SM-G960U using Tapatalk
68 degree hta
83mm bb
Hand brushed finish
