Seven months after I began this project, I've finally finished my full suspension 29er! This is my third steel bike, following two hardtails, the second of which is detailed here (https://forums.mtbr.com/frame-building/steel-29er-hardtail-v2-0-a-1092402.html). Some of the design work for this bike was documented here (https://forums.mtbr.com/frame-building/looking-input-steel-fs-29er-design-build-1094552.html).
It ended up being right around 140mm travel in the rear and I designed the geometry around a 160mm fork.
I had it powder coated with Prismatic Powders 'Illusion Lite Blue' with the 'Clear Vision' top coat. (PMS4621 and PPS2974). It looks incredible in person, especially in the sun, but I cannot get that to come across in a photograph.
Here's the geometry:
Head tube angle: 65˚
Effective seat tube angle: 76˚ (at my saddle height)
Stack: 653mm
Reach: 490mm
Chainstay Length: 435mm
Front-Center: 839mm
Wheelbase: 1274mm
BB Drop: 25mm
BB Height: 355mm (w/ ø760mm tires)
ST Length: 450mm
HT Length: 130mm
Fork Axle-Crown: 567mm (160mm Fox 36)
Fork Offset: 51mm
Stem Length: 45mm
and some highlights of the build list:
Fork: Fox 36 Factory, Fit4 damper, 160mm travel
Shock: Fox DPX2 Factory, 200x57mm
Groupset: SRAM GX/X01 Eagle, 32t by 10-50t, 175mm cranks
Brakes: Shimano XT M8020
Rotors: 180mm F/R (custom IS to 180mm post mount adapter for rear)
Dropper: Brand-X XL 170 x 30.9mm
Hubs: Industry Nine Torch
Tires: Maxxis 29x2.5" DHF (front) and Aggressor (rear)
2019,07,14-CRD_4755-2 by Callum Douglass, on Flickr
Stack: 653mm
Reach: 490mm
Front-Center: 839mm
Wheelbase: 1274mm
BB Drop: 25mm
ST Length: 450mm
HT Length: 130mm
Fork Offset: 51mm
Stem Length: 45mm
