I was gonna wait til Monday to do this, but I had some time to kill. Let me preface this review by stating that the fork has seen 10 days of riding, an oil change, and now 2 more days of riding. One thing to note on this fork if you are in the market for a Zoke, is that the oil level in the rebound leg was set too high from the factory, so for the first 10 rides, I was only using a max of 6 inches of travel.
When I first took this fork out on the trail, I noticed that it was going to take some time to break this puppy in, which I found unusual, as with Zokes of the past that I have owned, the forks felt great right from the get go. The first 5 rides or so felt harsh when riding down anything choppy, but the fact that the fork was so much stiffer than the Z-1 FR1 that it replaced left me grinning ear to ear. By the 6th ride or so, the fork started to come alive, and felt as buttery smooth as the Z-1 before it. This fork tracks better down the steep techy descents, and does not brake dive nearly as much as the 05 Z-1. Now some of the brake dive can be tuned out with a couple clicks of compression damping. My initial settings on the fork were 42 psi in the main chamber, with 5 clicks of compression.
The real test of this forks abilities came today out at little creek. When I changed the oil earlier this week, I went with 7.5 weight oil, just to get me thru the winter months. I will bump it up to 12 weight come summer time. I set both legs at 60mm from the top of the stanchions, which is what Zoke recommended as a max level. Today the idea was to see just how well the HS compression adjustement worked. I gotta say that the difference between full on, and full off is night and day. For DH, and long downhillls, I'd run this fork in the full off position, or no more than 5 clicks of compression. Any more than that, and the fork get noticeably stiffer. I took my pack off of multiple 5 footers to flat today to see what the different compression settings would do. My first couple of tries with no compression on, and the fork blew thru it's travel, and I really felt the bottom of the fork a couple of times. I added 10 clicks of compression, and the fork felt bottomless on the same drop. I was using all 170mm of travel, but no harsh bottom out. As for the ETA, it works as advertised, but will see little use on the trails I ride. In summary, so far this fork is the best thing I have ever ridden. My pack finally feels complete, to my wife's delight. This fork is not for everyone, but I'd say that if you are looking to build up one bike to do it all, then this is the fork that should adorn your steed. The A-C lengh is considerably shorter than last year's 66, so it still climbs well.
