I always ran full length housing for my Avid Mechs, and loved them. They were smooth as silk. I had friends who did not run full length housing, and I could definitely feel a difference when trying their brakes out.EvanSpikes said:
I always ran full length housing for my Avid Mechs, and loved them. They were smooth as silk. I had friends who did not run full length housing, and I could definitely feel a difference when trying their brakes out.EvanSpikes said:I am in the process of upgrading to a RS Reba fork and BB7 brakes on my 02 Rockhopper. My question is, is there any advantage/disadvantage to running a full length cable housing vs. open cable (no housing) along the top tube? I've read somewhere that running a full length housing provides less drag. If this is true, why does just about every bike come with the open cable? Thanks for any information/opinions on this subject...
Yes, Max99 is a Get Smart ref. I have 2 dogs, Maxwell Smart and 99. One of my favorite TV shows as a kid.Brizn said:It's a preference issue--as most things are. Not sure what you mean by "less drag", but full length housing will actually result in more friction and may make for harder pulling. Full length housing will surely keep your cables cleaner though. Split housing reduces friction and, I would think, makes for a smoother/quicker pull. But it sounds like Max99 (god I hope that's a Get Smart ref !) has had good luck running full length. Avid makes some cool stuff to check out: flack jacket, full metal jacket, etc.
correct. also a split housing gets dirt inside, which is the worst friction cause.there is less friction in a full length housing than a split housing because the fittings on the split housing, where the cable exits and enters the housing, causes drag/friction.
It sure does! I've been running full length shifter housing for the last six months, and it's still operating as new. (I'm also a big fan of full length brake housing!EvanSpikes said:Just an update... I ran full length housing to my new BB7s and am totally stoked at the silky smooth feel! Because I see no drawback (other than drilling out stock cable guides), I would totally recommend to anyone.
My only question is, does anyone know if running full length housing provides the same benefits for the shifter cables? Thanks...
and Specialized has switched to full length rear derailleur housing on the Epic FS bikes because it is less affected by the suspension movement.[email protected] said:It sure does! I've been running full length shifter housing for the last six months, and it's still operating as new. (I'm also a big fan of full length brake housing!)
It does add some weight, but unless you're an uber-weight weenie (not that there's anything wrong with that..) I think it's worth it.
- Greg
The answer to this question, I suspect, is tradition... it is most likely a weight-weenie decision carried over from road bikes, and has simply not been questioned.EvanSpikes said:...why does just about every bike come with the open cable?
More likely a carry over from when housing was lower quality and much more compressible.Speedub.Nate said:The answer to this question, I suspect, is tradition... it is most likely a weight-weenie decision carried over from road bikes, and has simply not been questioned.
I can tell you with absolute certainty that, prior to actually considering the benefits of full length housing, I thought of it as cheap, tacky, K*Mart, etc. -- especially growing up, before mountain bikes really hit mainstream.
As an aside, anyone here from the bay area remember the bikes given away by Matthew's TV & Stereo ("Steven Matthew David's, top of the hill, Daly City!") -- featuring bright yellow full length housing... point made?
So now every frame that enters the house gets the Dremeled cable stop treatment, and is quickly converted to full length housing runs.
https://forums.mtbr.com/showthread.php?t=130062
Ahhh! My road bike ignorance shows, no? I didn't even consider the "old fashioned" shifter placementshiggy said:Road bikes traditionally use full length brake housing. The use of housing stops and open runs is inspired by mtbs.
